altnmaintman
#1 Posted : Saturday, April 16, 2016 1:34:55 PM(UTC)
altnmaintman
A widow woman i try to help occasionally reports her 30+ year old Maytag oven overheats and burns what she is trying to bake. The lower heating element gets red hot, and the top element does not heat up. Could it be the thermostat? I hope not because I can not find a replacement part on line. Can someone help me out?
Appliance Medics
#2 Posted : Saturday, April 16, 2016 1:43:35 PM(UTC)
Appliance Medics
It very well could be a bad thermostat, with older machines that are completely mechanical that is a lot of time the only part that controls temperature. Check to make sure theRe is no shorted terminal on the element itself and also check that the thermostat bulb has not fallen from its bracket. Sometimes these scenarios can cause similar problems. Lastly if the thermostat is indeed bad with no calibration screw of any sort you may be able to find a generic to fit the oven, though this is a lot more difficult than it sounds. You must make sure it has the same terminals, mounts the same, and has the appropriate bulb length to fit the bracket, and same length of bulb tube so it can reach the desired mounting are. These are best found through a parts catalog with generic part manufacturers.
GE Oven overheats only in BAKE mode not convection (Oven Repair (including Ranges and Cooktops))
by mawinter 12/13/2017 11:01:45 AM(UTC)
Oven overheats (Oven Repair (including Ranges and Cooktops))
by Jessie Boone 6/9/2011 1:02:14 PM(UTC)
Whirlpool elec oven overheats then locks (Oven Repair (including Ranges and Cooktops))
by jeanking 5/22/2011 11:12:57 PM(UTC)
magic chef oven overheats (Oven Repair (including Ranges and Cooktops))
by jhelton007 12/25/2010 5:03:57 PM(UTC)
Thermador oven overheats (Oven Repair (including Ranges and Cooktops))
by aida.artenian@woodbury.ed 5/14/2010 9:10:52 AM(UTC)
oven overheats (F3... ) and won't turn off (Oven Repair (including Ranges and Cooktops))
by samnapril4 9/14/2009 7:19:05 PM(UTC)
Old Tappan Oven overheats (Dishwasher Repair)
by jbarkley123 7/1/2009 4:11:56 AM(UTC)
by mindylt 6/12/2009 5:56:50 PM(UTC)
Wall Oven overheats (Oven Repair (including Ranges and Cooktops))
by Normand 2/18/2009 12:19:27 PM(UTC)
My Roper Oven overheats/won't self clean f5e1 error (Oven Repair (including Ranges and Cooktops))
by vanillabean 1/21/2009 5:16:41 PM(UTC)
oven overheats, won't turn off (Oven Repair (including Ranges and Cooktops))
by rosepetal 1/5/2009 4:59:30 AM(UTC)
Oven overheats, (Oven Repair (including Ranges and Cooktops))
by tomcremers 1/1/2009 5:32:14 AM(UTC)
