AlexelA
#1 Posted : Thursday, April 7, 2016 9:54:33 AM(UTC)
AlexelA
Hi there. I've got t GE Gas Oven and both the broiler and the oven burner won't ignite. The glowbars (which I just replaced for new) both glow brightly and draw 2.57 A. I tested the two valves and there is continuity between the the connection tabs, which I understand is good. Also, the gas stove lights, so there is gas and power. I also flipped the switch on the regulator, but it had no effect.
I'm just an amateur and I usually Google my way through repairs. I thought after I got the low amp reading on the igniters that that was the problem for sure, but replacing didn't help.
Any ideas?
Thank you in advance for your responses.
cbmserviceguy
#2 Posted : Friday, April 8, 2016 10:19:08 AM(UTC)
cbmserviceguy
https://unitedservicersblog.com/...ogy-and-troubleshooting/
Go check out that article and watch the video. It explains in great detail how your oven works. Should answer all your questions. Take care!
Alexkourelis
#3 Posted : Friday, April 8, 2016 2:19:20 PM(UTC)
Alexkourelis
Ur gas valve needs replace. They are normally closed so when ohming them out u should have less then one ohm. On both sets of terminals on the valve.
