i have a 1991 caloric and the oven won't light. think it is igniter but worried if i replace it with one a few numbers off (parts wise) it might not work. It looks the same but the number is 0309151 instead of 0309159. is there much difference? By the way-how often do the burners malfunction on these? Before oven stopped working although we never smelled gas when it finally ignited there was a pop and the oven door even moved a bit-did not seem too safe. Would that be the burner needing cleaning or just the igniter? Thanks for any help-Dan
