my maytag range right front dual burner has lost the inside element. the main switch ( the knob up above) works ok for the outside element and the rocker switch seems ok also but the inside element doesn't work. In looking at the info on the maytag site I'm not too sure about the element shown there. Also need to know if there are hinges under the back side of the range top. thanks techfun5
