After setting a "Bake" temperature and pressing "Enter" the oven may shut off during warm up (temperature display goes blank). Usually once the oven gets to bake temperature everything works normally. It may go weeks between incidents. After the oven shuts off "Bake" temperature can be input again and the oven may or may not reach the desired temperature. When the event happens there is no beeping of any kind and the clock display remains illuminated and no codes are displayed. This happened with the warming drawer once also. If the oven sensor goes open or shorts will a code F3 or F4 be displayed and the oven shut off or is it possible for this sensor to intermittently fail in such a way as to not set a code and create this condition?
