| » gas oven problems |
Model Number: crg7500aae Brand: Maytag Age: 5 - 10 years
i have a gas range,when the oven is turned on it ignites, then heats to the required temperature ,then it normally cuts out .when the oven cuts back in to reheat to the required temperature i get a gurggling sound from the oven, even as the tube is lit .it sounds like when your barbecue blows out in the wind .i have installed a new igniter and have checked the brass jet for wear and dirt.the flame tube appears to be straight over the jet and all holes free of dirt. where should i turn next.
Remove the oven floor and the flame spreader.
Turn the bake "on" and watch the flame. The approximate length of the flame of the oven burner is a 1/2" distinct inner blue flame. If you see the distinct blue flame but lifting - close the burner air shutter (on the bottom of the burner tube) to the point where it will not cause the flame to lift or blow off the burner when cold. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com Last edited by Gene : 02-20-2008 at 06:53 PM. |
Remove the burner and, using a toothpick, clean the hole in the orifice.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
i removed the orfice checked and cleaned the tip and i also cleaned the inner tip and used canned compressed air , it seems to have cleared the problem i will try the oven for a day or two then advise further .thanks for the help
I'm glad you were able to fix it.
__________________
| Display Modes | |
| Oven Problems | mckay751 | Oven Repair (including Ranges and Cooktops) | 1 | 07-12-2009 10:51 PM |
| GE oven problems | Appdufus | Oven Repair (including Ranges and Cooktops) | 5 | 07-06-2009 01:43 PM |
| oven problems | wbusbee | Oven Repair (including Ranges and Cooktops) | 2 | 03-09-2009 07:31 PM |
| Oven problems | Jbates | Oven Repair (including Ranges and Cooktops) | 0 | 02-16-2009 03:36 PM |
| Oven problems | jejegar | Oven Repair (including Ranges and Cooktops) | 1 | 12-22-2008 05:21 AM |
