I have a Whirlpool gas range/oven. Model# gw395lepq00. the error codes: F2 E0 and F2 E1 come up which I believe means i need to replace the electronic control panel or key pad. I have unplugged the oven and pressed the cancel button, and have also tried to clean the ribbon, and the error codes still appear. My issue and question is how to remove the ribbon from the electronic control board? I am having trouble figuring this out. Do I just put a tool in the key part of the ribbon's connector and it will dislodge it? Is this difficult or do I need to call a technician? I don;t want to cause any damage to the control board, if the board is not the problem and the key pad is.
Any advice is appreciated.
Thank you!
