melvinrosebud
#1 Posted : Tuesday, March 1, 2016 9:58:41 PM(UTC)
melvinrosebud
I have a Whirlpool gas range/oven. Model# gw395lepq00. the error codes: F2 E0 and F2 E1 come up which I believe means i need to replace the electronic control panel or key pad. I have unplugged the oven and pressed the cancel button, and have also tried to clean the ribbon, and the error codes still appear. My issue and question is how to remove the ribbon from the electronic control board? I am having trouble figuring this out. Do I just put a tool in the key part of the ribbon's connector and it will dislodge it? Is this difficult or do I need to call a technician? I don;t want to cause any damage to the control board, if the board is not the problem and the key pad is.
Any advice is appreciated.
Thank you!
GE GTWN4250D1WS Electronic Control Board (Washer Repair)
by Flambdog 11/12/2020 12:19:56 PM(UTC)
electronic control board (Washer Repair)
by gompra 3/22/2017 10:53:54 AM(UTC)
Can Electronic Control Board be Repaired? (Oven Repair (including Ranges and Cooktops))
by Tambirita 10/13/2015 2:10:18 PM(UTC)
by mrzipfl 12/20/2012 12:58:21 PM(UTC)
freezer electronic control board (Refrigerator & Freezer Repair)
by barryss 7/19/2012 11:11:41 AM(UTC)
tried replacing door latch electronic control board (Washer Repair)
by sparks87144 10/13/2011 9:36:32 AM(UTC)
I replaced the electronic control board and the BIMETL-DEF (Refrigerator & Freezer Repair)
by johnogata 6/21/2010 9:03:03 AM(UTC)
Problem with Electronic Control Board? (Dishwasher Repair)
by Stevebca 11/3/2009 5:30:25 PM(UTC)
Removing Oven Electronic Control Board (Oven Repair (including Ranges and Cooktops))
by Avgenackis 3/19/2009 6:37:09 PM(UTC)
Electronic Control Board Clicking (Refrigerator & Freezer Repair)
by guinness39 12/6/2008 5:51:17 AM(UTC)
Help with electronic control board installation (Dryer Repair)
by Loriabrass 5/27/2008 3:39:32 PM(UTC)
