The bake element is not working at all. On another site it was suggested that I replace the control board and control panel. At a cost of @500.00 I did this as control panel was cracked above LED. I have tested the element it registers 17ohms just like the new element that I have not installed because the ohms are the same. I tested the wires to element they are getting no power in bake mode. The broil element does work so what is left to replace? Thanks
