Need help to figure out what is wrong with my Gas Oven. The top four burners work fine but when I turn on the Bake or Broil cycle; -the fan clicks on like normal -then a few seconds later I can hear what sounds like the valve for the gas open -but then when its supposed to click to light the burner inside the top of the oven the entire cycle turns off -it then resets itself and tries again Almost like a power trip but maybe its a safety thing because its not liteing the burner? This cycle will continue over and over, my un-educated guess would be the spark isn't liteing the burner so its recycling the timer but I have no idea. Has anyone ever have this problem or know what I need to replace? Thank you in advance. Chris.
