Discuss
electric oven - F-3 error code
 in
After we got the F-3 error code several times and the oven finally would not work at all, we
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » electric oven - F-3 error code
  #1 (permalink)
Old 02-19-2008, 07:42 PM
AKT AKT is offline
Junior Member
AKT is on a distinguished road
Default electric oven - F-3 error code
Model Number: JKP13G   Brand: GE   Age: More than 10 years
After we got the F-3 error code several times and the oven finally would not work at all, we replaced the oven sensor. This did not solve the problem. After further investigation, we found that the oven fan switch wasn't working so we replaced that. We tried using the oven again and it worked fine for about an hour. When we opened the door to check the food, we immediately got the F-3 error code again and now the oven won't work at all again. As soon as it starts to heat the F-3 code comes up and it starts beeping. What the heck is going on??? Help!!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-20-2008, 04:02 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the oven from the cabinet, remove the rear cover and check the sensor wire harness from the sensor plug to the control board.
Eliminate the sensor plug and connect wires using the high temperature porcelain wire nuts (part number AP3440522).
Check the sensor plug at the control board for the possible loose connection.
If all of above did not help then the control board has to be replaced.
In order to provide the right part number for the control board I need the complete model number of the unit.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Oven WEIRD Error Code 5ab sewsew Oven Repair (including Ranges and Cooktops) 4 10-07-2008 03:53 AM
"Probe error" on Bosch electric oven HBL 765 hbl765 Oven Repair (including Ranges and Cooktops) 2 01-28-2008 07:27 PM
Kitchenaid Oven Error code question MSA959 Oven Repair (including Ranges and Cooktops) 0 01-09-2008 01:13 PM
Frigidaire Oven F3 error code sbochen Oven Repair (including Ranges and Cooktops) 2 01-08-2008 09:38 AM
Oven error code Squillo Oven Repair (including Ranges and Cooktops) 0 12-05-2007 10:43 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
