Hi, my range JGS968SEK1SS has a peculiar issue with the oven. When I hit 'Broil' the oven heats up. All other modes can be activated, and the range would respond on the display as it should but there would be no heat. If the 'Convection' option is chosen the fan would not spin.... Please help! Thanks a lot!
