Hi..the oven model # is gone on the door, ( oven came with the house ) sometimes it will light..but usually after 10 mins or so i have to reach and tap the neck leading to the igniter tip..it will lit..but then anywhere from 30 secs on it give a deep poof sound and go out..it has stayed lit the entire time a few times,,but usually i need to tap it quite a few times to make sure my meal cooks..i have a feeling it is more then one part..also when I checked the oven upon moving in I found what looked like it might be a thermometer hanging from the inside top and pieces of it in the oven....Any ideas or help you have ir much appreciated....also, can i order the parts from you guys ?. Martin Penngrove, Ca
