All 4 burners light with no problem. If one burner is on and a second or third or fourth burner is turned on all of the burners start to fluctuate and their flames drop off to very little, as if the propane tank was running out. I did check the tank and I have plenty of propane,...over half full.
This started to happen all of a sudden. How can I fix the unstable pressure?
