How can I fix a stripped screw hole to the ignitor where it mounts inside the oven. Can I use a bolt with a lock nut? Do I need a specific type of bolt to handle the temps in the oven? I think one screw hole is stripped, and I know the other one still has a broken off screw that I couldn't remove. Thanks for any help you can give me, Don
