Discuss
Control electronics problems with KitchenAid
 in
I have two problems with this appliance: 1. When I close the door and latch on the bottom oven and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Control electronics problems with KitchenAid
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-15-2007, 10:59 AM
Muffie Muffie is offline
Junior Member
Muffie is on a distinguished road
Question Control electronics problems with KitchenAid
Model Number: KEBS207BWH2   Brand: Kitchen Aid   Age: 5 - 10 years
1. When I close the door and latch on the bottom oven and press the "CLEAN" switch, the message indicates the door is open. I suppose I could replace the "SWITCH" part or the "LATCH - DOOR" part. Any suggestions on how to decide?
2. The control panel seems to have a few crossed wires in terms of the instructions I give it versus the actions it tries to take. For example, asking for 450 degrees results in getting 420 degrees. Also, pressing "UPPER OVEN - BAKE" results in 160 degrees, the expected result from pressing "TEMP PROBE." Also, pressing "KITCHEN TIMER - SET" produces the result you would expect from pressing "CLOCK SET." My choice seems to be between replacing the Microcomputer or the Membrane Switch. Any suggestions on how to decide?
I have a rudimentary VOM that I can use for thngs like testing for continuity. In particular, the Membrane Switch is connected to the Microcomputer by a flexible flat cable. The Membrane Switch has 32 buttons and the flexible flat cable has 17 "pins," two of which form a visible loop and apparently do nothing. Is there a simple coding scheme that I could use to test the Membrane Switch? For example, pressing the "UPPER OVEN - BAKE" closes a circuit on pins 1 and 2 so I could test for continuity on pins 1 and 2 when I depress "UPPER OVEN - BAKE."
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
