I really need help in replacing the outer trim and front glass on my Whirlpool range. I have tried to align the glass into the 4 black clips that are on the side of the inner door (there are 2 on each side). It seems like the door is out of square. I am unable to get the clips to grab the glass.. Does the glass go inside the clips or do they push the glass out against the trim pieces. I have managed to break both the trim pieces and need to order replacements. Thank you
