The burners on the oven work fine. When using the oven the front panel gets very hot. If you use the burners and the oven together the appliance shuts down when the oven gets hot. The front panel goes blank. However, the burners are not effected. When the oven cools down the front panel begins working. The oven can be used again but will shut down when it get hot. Thanks in advance for your advice.
