Discuss
Magic Chef Wall Oven
 in
So I have a question. When I turn my oven on, the igniter comes on right away, however, it takes
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Magic Chef Wall Oven
  #1 (permalink)
Old 10-28-2015, 01:23 PM
Junior Member
Shenita is on a distinguished road
Default Magic Chef Wall Oven
Brand: Magic Chef   Age: 5 - 10 years
So I have a question. When I turn my oven on, the igniter comes on right away, however, it takes a few minutes before the burner heats up and light the flame. It eventually comes on but it just takes longer than usual for it to come on. I can use the oven and it cooks fine. After the oven is cut off and cool off for hours, you can sometimes smell gas.
I had a repairman look at it and the igniter is fine, there are no gas leaks anywhere. He thinks that the gas valve is going bad? Does that sound right or could it be the burner itself that is going bad on the oven. If that is the case, would that bad burner cause a smell of gas when the oven is off or would the gas valve be the cause.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef Wall Oven gas leak KathrynL Oven Repair (including Ranges and Cooktops) 0 09-20-2013 07:25 AM
Magic Chef Wall Oven Not Getting Hot Youngbuck Oven Repair (including Ranges and Cooktops) 4 04-27-2012 02:08 AM
Help with my Magic Chef wall oven Joe Garza Oven Repair (including Ranges and Cooktops) 1 01-14-2010 01:57 AM
Help with my Magic Chef wall oven Joe Garza Oven Repair (including Ranges and Cooktops) 0 01-12-2010 02:03 PM
magic chef wall oven trikerdave Oven Repair (including Ranges and Cooktops) 1 04-22-2009 01:14 PM
