Discuss
Fault code 7, JEN AIR Gas-Elec Range
 in
I turned on oven and after a few minutes the oven started beeping and Fault Code 7 appeared. I hit
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Fault code 7, JEN AIR Gas-Elec Range
  #1 (permalink)
Old 10-29-2009, 07:46 PM
Junior Member
Bigdigg is on a distinguished road
Post Fault code 7, JEN AIR Gas-Elec Range
Model Number: SVD48600W   Brand: Jenn-Air   Age: More than 10 years
I turned on oven and after a few minutes the oven started beeping and Fault Code 7 appeared. I hit the cancel off key and the beeping subsided for a minute or so then came on and started beeping again. I believe it the control panel. Is it difficult to replace and what is the correct part number and cost. Thank you
Ads By Google
Related Models
Jenn-Air SVD48600W Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD48600WC Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310S-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SD Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SF Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SG Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SK Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SR Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVD8310SU Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SVE47100B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47100WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47500W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600BC Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
  #2 (permalink)
Old 10-30-2009, 03:05 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for JENN-AIR SVD48600W | AppliancePartsPros.com
Here is a service manual which should help
http://www.servicematters.com/maytag...s/16010191.pdf
F7 is a shorted key error
It can be caused by one of 2 parts either the keypad or the control board.
See Section 4 is the parts above.
Item 2 switch-membrane is the keypad. Note that there are different colors.
Item 3 is the Electronic oven control assembly
Most of the time it is the keypad that is bad.
One way to check it is to use a meter on the ribbon cable to see if a key is always closed. Unfortunately the manual does not give a pin-out for your unit and I am not sure that one on Page 1-16 for a SVE47600 is the same as yours.
You could unplug the keypad ribbon cable and then give it a try if the error does not come up again odds are high that it is the keypad.
Be sure to remove power from the unit when doing this.
__________________
  #3 (permalink)
Old 10-30-2009, 05:49 PM
Junior Member
Post Jen Air
One detail I forgot to mention was the display board has been fading in and out for about the last 60 days. It would go blank and I could tap the window of the display board and it would come back where you could read, Temp and time. Lately it went out altogether. You could set the temp of the oven and hear the chime. Also, if you set the timer it would go off when done, even though nothing could be read on the display. The oven worked fine. But right when it the F7 symptoms appeared you could read the display again. Does this narrow down what the problem is?
  #4 (permalink)
Old 10-30-2009, 07:04 PM
Senior Expert
APP Volunteer
Default
That does sound like more of a control board problem than a keyboard problem.
I would still try cleaning the contacts.
Also I would check the solder joints on the board for a bad one.
Cold solder joints are often a gray instead of silver color.
Wiggle the capacitors (small cans) a little while watching the back side of the board. If the leg moves then tou have a bad solder joint.
__________________
  #5 (permalink)
Old 11-02-2009, 12:47 PM
Junior Member
Default Access to control panel
I removed the four hex screws from under the access panel and like instructed by the manual I pulled out and down and I cannot get the panel to come out in order to get access to the control board. Any suggestions.
  #6 (permalink)
Old 11-02-2009, 09:00 PM
Senior Expert
APP Volunteer
Default
I found this on Applianceblog
I reviewed the service manual which states,”remove the four hex head screws from the bottom of the control panel. Grasp the panel by the sides and pull out and down”. I also removed the two side trim pieces to confirm there were no screws there…none. When I pull on this I feels as though something still has a hold of the top center (over display) and I don’t want to break it.
I’ve read posts where everyone says how easy this was to do in 5 minutes. Perhaps someone who has done this recently knows the trick and would share.
For the benefit of future folks looking here I will explain. According to the service manual, "remove the four...(see above post)". What they fail to inform is that behind each knob is a screw holding the control to a bracket screwed to the frame. Once the four lower screws were removed followed by the screws holding the knobs in place the control panel slid right down. Replaced the clock in about five minutes, replaced the screws and danged if it don't work.
__________________
  #7 (permalink)
Old 11-03-2009, 03:03 PM
Junior Member
Smile Oven is fixed
Thank you for your help. Removing the four little screws behind the Gas Control knobs worked. The access panel came right off. I disconnected the wiring cleaned the prongs with alcohol and put it back together. Plugged it in and it works. Thanks, saved me money.
  #8 (permalink)
Old 03-13-2010, 02:54 PM
Junior Member
Default Replacement keyboard does not work
I have been disassmbling the removing the switch panel and cleaning the contacts since I first wrote asking for help. That worked until the latest attempt the alarm fault code kept coming on so I decided tho finally buy a new Switch Membrane keyboard. I installed it today and everything worked fine except the cancel off key. So now I can turn the oven on but I can't turn it off. Did I do something wrong or do you think the membrane keyboard is defective?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fault Code F- BorisLetus Oven Repair (including Ranges and Cooktops) 1 07-08-2011 11:06 AM
Jennair Range Top Fault Code pheyden Oven Repair (including Ranges and Cooktops) 1 09-16-2009 03:11 AM
bosh elec range error code jodijeter Oven Repair (including Ranges and Cooktops) 0 05-22-2008 05:55 PM
fault code f-9 Lou Barta Microwave Repair 1 04-03-2008 07:26 PM
kitchenaid range/oven kgst300bwh1 'Err' fault code when over 260 deg dansanjose Oven Repair (including Ranges and Cooktops) 2 03-22-2008 02:49 PM
