zell66
#1 Posted : Wednesday, October 14, 2015 7:16:13 AM(UTC)
zell66
upper unit works fine lower unit dead.
after using self clean mode on lower it has not worked. I have tried to reset high temp. relay but nothing.
when i turn on lower unit I do hear a series of clicks but broiler and oven element nothing.
#2 Posted: : Wednesday, October 14, 2015 1:31:48 PM(UTC)
Many units have a thermal cutoff that kills power to the elements.
It is usually mounted on the back of the oven.
But some units have it on the top of the oven.
zell66
#3 Posted : Wednesday, October 14, 2015 2:09:57 PM(UTC)
zell66
thank you for your response. Here are my limits, lol, what does a thermal cutoff look like on these units? So I know what I am looking for.
#4 Posted : Thursday, October 15, 2015 1:26:24 AM(UTC)
[COLOR="Blue"]Here are my limits, lol, what does a thermal cutoff look like on these units?[/COLOR]
I do not know as you did not include a model number.
Even with a model number I may not be able to find it as I do not have access to Dacor info.
On other brands they look like the following
Part number: AP4096908
zell66
#5 Posted : Thursday, October 15, 2015 4:46:22 AM(UTC)
zell66
thank you for picture,
i found the wiring diagram and it has 3 models on front
ECS227/230
MCS227/230
PCS227/230
were is the best place to look to locate this item and test it?
#6 Posted : Thursday, October 15, 2015 6:17:32 AM(UTC)
I went to the Sears parts site and searched for ECS227.
If you look in the Cell Assy 1 section I think Item 14 (part number 62775) is the hi-limit thermostat.
Looks like it is mounted ion the top of the oven.
If I then look up 62775 on AppliancePartsPros the following comes up.
The red dot in the center is probably a reset button.
Push it in to reset the thermostat.
Click on the picture for more info about the part.
Part number: AP3391739
zell66
#7 Posted : Thursday, October 15, 2015 8:10:10 AM(UTC)
zell66
I have tried resetting that switch and it does not seemed to be tripped. I even tried disconnecting lower unit and wiring into upper units high temp limiter switch and still nothing.
#8 Posted : Thursday, October 15, 2015 8:24:10 AM(UTC)
Sorry but I cannot help anymore as I do not have access to Dacor info.
The upper element works so you have 240 volts.
I do not know if this unit has two hi-limits in it one for the top unit and one for the bottom unit.
All I can suggest is that you trace the element wires.
zell66
#9 Posted : Thursday, October 15, 2015 8:30:42 AM(UTC)
zell66
thank you. and yes i do have 2 high limits.
#10 Posted : Thursday, October 15, 2015 12:47:42 PM(UTC)
One thing I can add is do not trust the pop outs measure it with a meter to be sure it is OK.
Also some units use a similar shaped thermostat to run the cooling fan. That thermostat is usually on the top of the oven.
Dacor Double Wall Oven-replace lower oven relay board (Oven Repair (including Ranges and Cooktops))
by CatsR 12/27/2010 10:56:52 AM(UTC)
dacor double wall oven lite inop (Oven Repair (including Ranges and Cooktops))
by cfilice 11/13/2008 5:38:30 PM(UTC)
