Discuss
code f31
 in
I am looking for info before I go to my daughters to trouble shoot Saturday. Her range will notheat and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » code f31
  #1 (permalink)
Old 10-29-2009, 06:47 PM
sparkyjc sparkyjc is offline
Junior Member
sparkyjc is on a distinguished road
Default code f31
Model Number: fef366emd   Brand: Frigidaire   Age: 1 - 5 years
I am looking for info before I go to my daughters to trouble shoot Saturday. Her range will notheat and get f31 code, all that I read on the net says oven probe faulty or wiring or EOC. She says she has no probe so I figure more than likely EOC. Any help greatly appreciated!!!
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 10-30-2009, 04:21 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Replacement parts for FRG FEF366EMD | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodin.../316441437.pdf
I believe they are referring to the oven sensor ( Item 37 in Section 2 note it is listed at the bottom of the page as F37) and not a meat probe.
Here is a link with more info
http://www.applianceaid.com/elecrange.html
Check out Items 7, 8 and 21
__________________
  #3 (permalink)
Old 10-30-2009, 06:32 PM
Junior Member
Default Thanks
Thanks Denman
I will go tomorrow to trouble shoot.
Thanks for the info. it most definitely is a help!!
  #4 (permalink)
Old 11-01-2009, 02:56 PM
Junior Member
Default Checked it out
Took off back cover and read probe 1.079 kohms. Figure thats OK. Unplugged wiring plug on EOC and cleaned connections(was slight grime on top of plug @ connections, but didn't appear shorted). All working Ok when I put it all back together yesterday. I heated top element till red then did bottom till red. Daughter called today and said its getting the same f31 code again and will not heat.
  #5 (permalink)
Old 11-02-2009, 04:03 AM
Senior Expert
APP Volunteer
Default
Looks like it is intermittent.
F31 can be an open or a short.
I would clean the contacts.
Unplug the unit and use electronics contacts cleaner or isopropyl alcohol and a tooth brush. Do not reconnect till all the solvent has evaporated.
Pull the control board and slightly wiggle the pins while watching the soldered side. Look for any sign of the pin moving. A magnifying glass can help here.
Also look at the solder color, if it is gray instead of silver you may have a cold solder joint. Also a cold solder joint if it has pin holes.
I would also look at the copper tracks on the board for hairline cracks.
Trace the tracks from the connector to the next component connection, again checking for a cold/bad solder joint.
If all the above does nothing then all you are left with is a crap shoot.
Which to replace first the temperature sensor or the board or both.
I think I would try the sensor first as it is less dollars ($16.96).
Murphy's Law is the second part you replace will be the fix.
__________________
  #6 (permalink)
Old 11-04-2009, 04:23 PM
Junior Member
Default Cleaned
Clean the eoc and checked for cold solder (found none) now get f13 code. Unplugged for 30 seconds, still get f13 code. I quess new eoc would be next step
quote=denman;144875]Looks like it is intermittent.
Murphy's Law is the second part you replace will be the fix.[/quote]
  #7 (permalink)
Old 11-04-2009, 06:13 PM
Senior Expert
APP Volunteer
Default
Yes Code 13 is a checksum error so odds are high it is on the EOC
__________________
  #8 (permalink)
Old 11-10-2009, 05:13 PM
Junior Member
Default How to
how do I remove the old overlay and install on new eoc
  #9 (permalink)
Old 11-10-2009, 07:13 PM
Senior Expert
APP Volunteer
Default
You could try heating it up with a hair dryer and peeling it off.
Odds are very high that you will be buying a new one.
It will probably warp or leave most of the glue on the old controller.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
code OE ret0801 Dishwasher Repair 3 08-22-2009 11:32 AM
GE Code F2 tom1c Oven Repair (including Ranges and Cooktops) 3 07-23-2009 07:22 AM
dr code comes one LMPaulchek Dryer Repair 0 04-30-2009 02:42 PM
F1 code Randy Hiltner Oven Repair (including Ranges and Cooktops) 0 07-08-2008 09:55 AM
Got a Code F3 Fishfinderiii Oven Repair (including Ranges and Cooktops) 3 07-01-2008 09:26 PM
