Have a Jenn-Air range that won't stay hot. Will preheat and hold temperature pretty consistent. Oven element glows bright red during preheat. Have left on for over an hour set at 500 degF everything fine. Open door and put in food and close. Within 10 minutes, temperature down below 350 and heater element not coming on. Checked temperature sensor and was 1090 ohms, which i think is normal. Any suggestions? I have read other posts where the control board and element was replaced but it didn't look like that was always successful.
Thanks,
Pat
