Hello I have an oven issue that the bake does not ignite The broiler works I have checked the resistance of both igniters and both are the same think it was 240 ohms If both igniters have the same resistance and one works and the othe doesn't ( as far as allowing gas through to ignite ) is there another problem elsewhere.....thanks Chris
