The oven bake burner comes on at high flame for about 30seconds then goes down to a small flame and stays that way until I shut it off then turn it back on then does the same thing again. The broil burner works fine and all stove top buners work fine . I just changed the temp sensor part #WB21X5301 but is still doing the same thing. Any thoughts
