Discuss
Soft pop noise, bit of smell, panel not working
 in
Hi there: This is a great forum, I just can't seem to find someone that has put up the same
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Soft pop noise, bit of smell, panel not working
  #1 (permalink)
Old 10-28-2009, 07:59 PM
Junior Member
BobbyTony is on a distinguished road
Smile Soft pop noise, bit of smell, panel not working
Model Number: PGLEF385CS2   Brand: Frigidaire   Age: 5 - 10 years
Hi there:
This is a great forum, I just can't seem to find someone that has put up the same specific info that I have in order to create a good diagnosis. I live in Fort McMurray, home of the Oil Sands, and a northern city with little in the way of service repairfolk. Our landfill gets a lot of appliances that just have popped relays, etc. because it is cheaper to buy knew than to diagnose and fix or there is just no one to find to fix.
So anyway, my problem. Went to start up my Frigidaire Smooth top range tonight, (Bake @ 400F) and as I walked away from it I heard a pop and could smell a bit of burning. The circuit panel didn't break, and the range panel went dead. Unplugging and resetting the panel breaker as options didn't change the scenario.
All of the range burners work, oven light works, etc. Just can't instruct the oven to turn on. I looked at the oven burners and found no instances of burning or welding. Took off the back panel and got a good woof of burnt stuff, so I am thinking that one of the relays in the panel may have blown.
Is there anything for me to test before I try to replace the panel on the range? The thing was built in 2003 so I am not sure how much luck I will have on the replacement part.
Thank you for your help,
Bob
Ads By Google
Related Models
Frigidaire PGLEF385CS2 ELECTRIC RANGE
Frigidaire PGLEF385CS3 ELECTRIC RANGE
Frigidaire PGLEF385CS4 Frigidaire Canada/electric Range
Frigidaire PGLEF385EB1 Frigidaire Canada/electric Range
Frigidaire PGLEF385EB2 Frigidaire Canada/electric Range
Frigidaire PGLEF385EB3 Frigidaire/range
Frigidaire PGLEF385EB4 Frigidaire Canada/electric Range
Frigidaire PGLEF385EB5 ELECTRIC RANGE
Frigidaire PGLEF385EB6 ELECTRIC RANGE
Frigidaire PGLEF385EC1 Frigidaire Canada/electric Range
Frigidaire PGLEF385EC3 Frigidaire/range
Frigidaire PGLEF385EC4 Frigidaire Canada/electric Range
Frigidaire PGLEF385EC6 ELECTRIC RANGE
Frigidaire PGLEF385EC7 ELECTRIC RANGE
Frigidaire PGLEF385EC8 ELECTRIC RANGE
Frigidaire PGLEF385EQ1 Frigidaire Canada/electric Range
Frigidaire PGLEF385ES1 Frigidaire Canada/electric Range
Frigidaire PGLEF385ES2 Frigidaire Canada/electric Range
Frigidaire PGLEF385ES3 Frigidaire/range
Frigidaire PGLEF385ES4 Frigidaire Canada/electric Range
Frigidaire PGLEF385ES5 ELECTRIC RANGE
Frigidaire PGLEF385ES6 ELECTRIC RANGE
Frigidaire PGLEF387CS4 Frigidaire/electric Range
Frigidaire PGLEF387CS5 Frigidaire/electric Range
Frigidaire PGLEF388CS4 Frigidaire/electric Range
Frigidaire PGLEF388CS5 Frigidaire/electric Range
Frigidaire PGLEF388ES1 Frigidaire/electric Range
Frigidaire PGLEF388ES2 Frigidaire Canada/electric Range
Frigidaire PGLEF388ES3 Frigidaire Canada/electric Range
Frigidaire PGLEF388ES4 Frigidaire/range
Frigidaire PGLEF388ES5 Frigidaire Canada/electric Range
Frigidaire PGLEF388ES6 ELECTRIC RANGE
Amana PGO-151 RANGE- S/C S/I DDRAFT GAS
Amana PGO191 SURFACE UNIT- GAS
Frigidaire PGP332LD3 Wwh(v1) / Gas Cooktop
Frigidaire PGP332LW3 Wwh(v2) / Gas Cooktop
General Electric PGP953DET1BB GAS COOKTOP
General Electric PGP953DET1WW GAS COOKTOP
General Electric PGP953SET1SS GAS COOKTOP
General Electric PGP959SET1SS GAS COOKTOP
General Electric PGP976DET1BB GAS COOKTOP
General Electric PGP976DET1WW GAS COOKTOP
General Electric PGP976SET1SS GAS COOKTOP
General Electric PGP986SET1SS GAS COOKTOP
General Electric PGP989DN1BB GAS COOKTOP
General Electric PGP989SN1SS GAS COOKTOP
General Electric PGP989TN1WW GAS COOKTOP
General Electric PGP990BEL1BB GAS COOKTOP
General Electric PGP990DEN1BB GAS COOKTOP
General Electric PGP990DEN1WW GAS COOKTOP
General Electric PGP990DEN2BB GAS COOKTOP
General Electric PGP990DEN2WW GAS COOKTOP
General Electric PGP990SEL1SS GAS COOKTOP
General Electric PGP990SEN1SS GAS COOKTOP
General Electric PGP990WEL1WW GAS COOKTOP
Thermador PGR364GDZS
Thermador PGR364GLZS
Thermador PGR366ZS
Maytag PGR4100BDW RANGE- F/S STD GAS
Maytag PGR4102CDH RANGE- F/S STD GAS
Maytag PGR4102CDT RANGE- F/S STD GAS
Maytag PGR4202BDH RANGE- F/S STD GAS
Maytag PGR4202BDT RANGE- F/S STD GAS
Maytag PGR4305CDH RANGE- F/S STD GAS
Maytag PGR4305CDT RANGE- F/S STD GAS
Maytag PGR4310CDQ RANGE- F/S STD GAS
Maytag PGR4310CDW RANGE- F/S STD GAS
Maytag PGR4405CDH RANGE- F/S STD GAS
Maytag PGR4405CDS RANGE- F/S STD GAS
Maytag PGR4405CDT RANGE- F/S STD GAS
Maytag PGR4409ADH RANGE- F/S STD GAS
Maytag PGR4410ADQ RANGE- F/S STD GAS
Maytag PGR4410ADW RANGE- F/S STD GAS
Maytag PGR4410BDQ RANGE- F/S STD GAS
Maytag PGR4410BDW RANGE- F/S STD GAS
Maytag PGR4410CDQ RANGE- F/S STD GAS
Maytag PGR4410CDW RANGE- F/S STD GAS
Maytag PGR4420LDQ RANGE- F/S STD GAS
Maytag PGR4420LDW RANGE- F/S STD GAS
Maytag PGR5702BDH RANGE- F/S STD GAS
Maytag PGR5702BDT RANGE- F/S STD GAS
Maytag PGR5705BDH RANGE- S/C F/S GAS
Maytag PGR5705BDT RANGE- S/C F/S GAS
Maytag PGR5710BDC RANGE- S/C F/S GAS
Maytag PGR5710BDQ RANGE- S/C F/S GAS
Maytag PGR5710BDW RANGE- S/C F/S GAS
Maytag PGR5715BDQ RANGE- S/C F/S GAS
Maytag PGR5715BDW RANGE- S/C F/S GAS
Maytag PGR5720LDQ RANGE- S/C F/S GAS
Maytag PGR5720LDW RANGE- S/C F/S GAS
Maytag PGR5750LDQ RANGE- S/C F/S GAS
Maytag PGR5750LDS RANGE- S/C F/S GAS
Maytag PGR5750LDW RANGE- S/C F/S GAS
Maytag PGS3759BDB RANGE- S/C S/I GAS
Maytag PGS3759BDS RANGE- S/C S/I GAS
Maytag PGS3759BDW RANGE- S/C S/I GAS
General Electric PGS908BEM1BB Gas range
General Electric PGS908BEM2BB GAS RANGE
General Electric PGS908BEM3BB GAS RANGE
General Electric PGS908CEM1CC Gas range
General Electric PGS908CEM2CC GAS RANGE
General Electric PGS908CEM3CC GAS RANGE
General Electric PGS908DEP1BB GAS RANGE
General Electric PGS908DEP1CC GAS RANGE
General Electric PGS908DEP1WW GAS RANGE
General Electric PGS908DEP2BB GAS RANGE
General Electric PGS908DEP2WW GAS RANGE
General Electric PGS908SEM1SS Gas range
General Electric PGS908SEM2SS GAS RANGE
General Electric PGS908SEM3SS GAS RANGE
General Electric PGS908SEP1SS GAS RANGE
General Electric PGS908SEP2SS GAS RANGE
General Electric PGS908WEM1WW Gas range
General Electric PGS908WEM2WW GAS RANGE
General Electric PGS908WEM3WW GAS RANGE
General Electric PGS968BEM1BB GAS RANGE
General Electric PGS968BEM2BB GAS RANGE
General Electric PGS968BEM3BB GAS RANGE
General Electric PGS968DEP1BB GAS RANGE
General Electric PGS968DEP2BB GAS RANGE
  #2 (permalink)
Old 11-19-2009, 07:14 PM
Junior Member
JFinger is on a distinguished road
Default Big pop noise, breaker broke, but still works...
We are having a similar issue with our Frigidaire Self Cleaning Oven (electric).
Our POP issue has been happening for the past four or five weeks.
All four burners work well, as do the broiler and bottom oven elements.
But sometimes when using the oven with other pots going on the top, we'll get a burning smell and perhaps a bit of light smoke from the back, electrical smoke it seems, and then POP there will be a white light from the oven area and the whole oven will turn off, due to the power breaker flipping. So I go to the garage, flip the breaker to turn it on again, and the stove and oven continue working.
Very strange.
Everything still works, unbelievably so. I did make sure the house wouldn't burn down, it's not like we were completely freaked out. Heh.
I was thinking it might be the sensor to the oven - perhaps it was getting too hot in there and it flipped the breaker.
I opened the back of the oven, just to take a look. I found a slight darkened color in the middle area, where the two wires go to feed the top element of the oven. But it all looked intact, it all looked good.
But I did find that the backside of the oven light was darkened, almost charcoalish, but just on the two tabs that keep the white light bulb holder in place. That was strange, because the light still worked. So just for kicks, after I put the backside on again, I took out the light bulb to see if that would help. I turned on the oven to 425F and it worked fine with no smell or burning sensation. So then we added a top burner - put on some tea. All was OK, no burning smell.
So after all this, could it have been the light fixture? And by taking out the bulb it helped this situation? Perhaps. If it happens again (POP) I'll post.
A week before Thanksgiving too...
  #3 (permalink)
Old 11-19-2009, 07:22 PM
Junior Member
Default
My pop noise was solved by replacing the Control Unit. Hope yours gets figured out! Bob
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
microwave makes loud noise & awful smell mak101376 Microwave Repair 0 01-12-2010 08:15 AM
GE dryer is making a loud noise and burning smell stu77n Dryer Repair 1 12-14-2009 04:18 PM
Burned rubber smell and scraping noise ccacace Washer Repair 1 04-13-2009 02:55 PM
Washer failed to agitate, burning smell, humming from control panel ksford1 Washer Repair 4 02-20-2008 12:15 PM
Washer failed to agitate, burning smell, humming from control panel ksford1 Washer Repair 1 02-19-2008 02:40 AM
