I have two burners with intermittent spark. Front left and rear right. The other two operate normally. I've noticed when I turn on the burners that operate as they should, I see spark on the other burners. When the intermittent burners are tried there is no spark. Do you think it is a couple of spark switches failing? Or the spark module?
Thanks, Mike
