Discuss
Whirlpool Oven won't clean
 in
I engaged the oven lock and set the cleaning cycle controls. The oven heated, the door locked, but the "
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Oven won't clean
  #1 (permalink)
Old 02-18-2008, 08:14 PM
pakeha pakeha is offline
Junior Member
pakeha is on a distinguished road
Default Whirlpool Oven won't clean
Model Number: SF365BEWN3   Brand: Whirlpool   Age: More than 10 years
I engaged the oven lock and set the cleaning cycle controls. The oven heated, the door locked, but the "cleaning" light did not come on. After 4 hours, the cycle ended and the lock disengaged. When I opened the door it was evident that no cleaning had taken place. Suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-19-2008, 05:38 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The self clean did not work because you did not set the start and the stop time on the oven clock as described in the "Use and Care" book (pages 21 through 23).
Here are the break down diagrams for the Whirlpool range Model SF365BEWN3
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-19-2008, 06:15 PM
Junior Member
Default
I followed the directions exactly as listed in the guide. As I said, the oven heated but the "cleaning" light never came on. The cycle ended at the time I had set it for.
Reply
« electric oven | F2 »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven does not work after self clean. Shows fault code F1 Nicolez123 Oven Repair (including Ranges and Cooktops) 3 02-11-2008 12:06 PM
Oven not working after auto clean lhensley Oven Repair (including Ranges and Cooktops) 3 02-04-2008 07:24 PM
Built in electric self clean oven Ladydi Oven Repair (including Ranges and Cooktops) 5 12-11-2007 01:25 PM
oven wont self clean jfisher915 Oven Repair (including Ranges and Cooktops) 1 12-03-2007 01:35 PM
Oven will not bake broil or clean feinerl Oven Repair (including Ranges and Cooktops) 5 10-24-2007 10:17 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
