| » digital readout faint |
Model Number: SMW272YP Brand: Thermador Age: 5 - 10 years
The clock and the temperature readout has slowly dimmed and now we can't read the Display.This unit has touch pad controls. Thoughts on what part(s) to change? Thanks
Related Models |
Replacement parts for SMW272YP models | AppliancePartsPros.com In 95% of the cases the control/display board has to be replaced. It looks like this came as a kit see Item 11 in Section 18. Unfortunately this is no longer available. The description does give a phone number for a repair depot. There are number of companies that you can find on the web that will fix appliance control boards. Here is a long thread which goes into this problem Thermador display is very dim
__________________
Since parts aren't available, all you can hope for is to brighten it up a bit temporarily if it's not gone too far.
You can clean the front of the display glass and the rear of the display window with a dampened soft cloth.
__________________
William E. Miller † prototech@usa.net |
| Display Modes | |
| F5 code on Jenn-Air control surface readout | thom2 | Oven Repair (including Ranges and Cooktops) | 0 | 06-01-2009 10:18 AM |
| LED readout gone blank | echad8237 | Oven Repair (including Ranges and Cooktops) | 0 | 03-16-2009 10:01 AM |
| actual temperature of oven less than LCD readout | daprice5144 | Oven Repair (including Ranges and Cooktops) | 1 | 11-28-2008 04:10 PM |
| Display very faint | Brian Thomas | Microwave Repair | 2 | 09-23-2008 08:48 PM |
| Maytag Gemini temp readout not correct | DougW | Oven Repair (including Ranges and Cooktops) | 0 | 05-18-2008 04:54 PM |
