dihahey
#1 Posted : Tuesday, June 9, 2015 4:31:34 PM(UTC)
dihahey
When I turn on the self cleaning, the stove beeps and says lock door. I lock it and it continues to read lock door and then shuts off. I have locked it and pulled on it and it feels locked. What could be causing this? There is nothing else wrong with the stove. TIA!
#2 Posted : Tuesday, June 16, 2015 2:39:18 AM(UTC)
Below are your parts
Parts for GE JBP62DM2WW Range - AppliancePartsPros.com
Note the above model does not have a 0 in it's model number.
Could be that the switch on the door lock assembly is not closing when you lock the door.
This is what tells the control board that the door is actually locked.
Could be a bad/loose connection between the door lock switch and the control board.
Could be a bad control board.
