stubbers
#1 Posted : Monday, June 8, 2015 1:03:00 AM(UTC)
stubbers
The large burner on our LG glasstop range won't turn off. It has HS on the burner display. How can I disconnect this burner for now and what do I need to replace to fix it?
#2 Posted : Monday, June 8, 2015 3:31:35 AM(UTC)
A model number might be helpful.
Find your model number - AppliancePartsPros.com
It may be the infinite switch for this element.
stubbers
#3 Posted : Monday, June 8, 2015 4:28:12 AM(UTC)
stubbers
I found the model number it is LRE304538T/01. Is the switch hard to replace? Thanks for your expertise
#4 Posted : Monday, June 8, 2015 6:38:25 AM(UTC)
Sorry but I cannot find any tech data on this unit.
It looks like it does not use infinite switches (knobs) but is controlled electronically so you need a wiring diagram to figure out what is wrong.
