Barry Jumper
#1 Posted : Wednesday, June 3, 2015 11:46:43 AM(UTC)
Barry Jumper
Get F-7 code and all research says temperature sensor, so $35 later and sensor changed, still get F-7 code. What do I check next?:mad: :confused:
Simon / APP Team
#2 Posted : Wednesday, June 3, 2015 2:57:37 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Barry.
You can check the sensor with multimeter for continuity. It should show resistance between 1100 and 1200 Ohms at room temperature. Also, you should measure the resistance again at the main control board plug so this way you are testing the harness too, because often the sensor's connector plug may cause the problem. In case if the tests shows the sensor is good, then most likely the main control board is faulty.
The oven Part number: AP4442099
Main control board Part number: EBR74632605
Thank you. Keep us posted.
Best,
Simon.
LG oven can’t use both bake/broil (Oven Repair (including Ranges and Cooktops))
by Whitelightnin92 1/29/2021 6:07:51 PM(UTC)
LG oven Model 3081 ST (Oven Repair (including Ranges and Cooktops))
by TSolar 10/23/2020 11:16:22 AM(UTC)
LG Oven not reaching temperature (Oven Repair (including Ranges and Cooktops))
by cblaines 9/26/2019 12:00:11 PM(UTC)
LG Oven Relay Board Keeps Burning (Oven Repair (including Ranges and Cooktops))
by greenman1985 8/15/2017 4:07:54 PM(UTC)
LG oven burns bread (Oven Repair (including Ranges and Cooktops))
by ponylady 12/24/2011 7:18:29 PM(UTC)
