MurrayParrish
#1 Posted : Monday, May 25, 2015 2:18:38 PM(UTC)
MurrayParrish
When you turn the right front burner switch to ON, both the right front and and right back burners activate. What do I need to replace?
#2 Posted : Tuesday, May 26, 2015 5:00:07 AM(UTC)
Parts for Jenn-Air JED8345ADB Cooktop - AppliancePartsPros.com
See the attachment for the wiring diagram
I would say that the right rear infinite switch needs replacing
(it's H2 to L2 contact6s are probably welded together).
You could double check this by removing the power from the unit and checking them with a meter.
Burner heating without cooktop being switched on (Oven Repair (including Ranges and Cooktops))
by nvreds 2/25/2024 10:40:40 AM(UTC)
Induction cooktop EHI965BA error E9 (Oven Repair (including Ranges and Cooktops))
by Guest 11/28/2023 8:00:28 PM(UTC)
Bosch Induction Cooktop NIT3065/UC Non-Responsive (Oven Repair (including Ranges and Cooktops))
by trishglxk 10/3/2023 9:18:30 AM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
How to remove the sticky screws in GE cooktop? (Oven Repair (including Ranges and Cooktops))
by Guest 4/9/2023 10:34:15 AM(UTC)
removing cooktop control panel on LG double oven (Oven Repair (including Ranges and Cooktops))
by Hurdles 4/4/2023 11:41:26 AM(UTC)
Frigidaire FEF369CGSB - Strange Cooktop Behavior (Oven Repair (including Ranges and Cooktops))
by trymes 3/22/2023 5:59:36 PM(UTC)
Kitchen aid/whirlpool Induction Cooktop Fuses (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 8:42:15 AM(UTC)
THERMADOR COOKTOP PCG366G (Oven Repair (including Ranges and Cooktops))
by pjl2000 11/20/2022 6:48:33 PM(UTC)
Heartland cooktop elements (Appliance Parts)
by Guest 10/11/2022 11:30:11 AM(UTC)
Installing Frigidaire FGGC3047QS Gas Cooktop (Oven Repair (including Ranges and Cooktops))
by Samkat923 8/2/2022 7:26:14 AM(UTC)
Thermador cooktop, no spark or gas for XLO burners (Oven Repair (including Ranges and Cooktops))
by Guest 3/26/2022 5:48:44 AM(UTC)
Cooktop anamoly (Oven Repair (including Ranges and Cooktops))
by RodB 2/17/2022 2:08:20 PM(UTC)
KitchenAid Gas Cooktop Solenoid Diagnosis (Oven Repair (including Ranges and Cooktops))
by Nothing Finer 1/17/2022 9:09:30 AM(UTC)
Help ID Frigidaire cooktop. (Oven Repair (including Ranges and Cooktops))
by jacmeen 1/14/2022 2:18:32 PM(UTC)
