You have been a member since:: 5/22/2015(UTC) Posts: 2
KXD4636YSS0 downdraft vent does not come up at all. Here is what happened.
1. I pressed the top switch, downdraft started coming up. 2. Before it settles down, I removed one of the filters for cleaning. Suddenly it started going down by itself. 3. It went down and has only 1 filter inside, does not come up now even after pressing the button multiple times.
Did the button go wrong? Is the switch circuit not complete with only 1 filter left inside?
How Do i bring up the downdraft vent to put back the filter?
Any help is greatly appreciated.
Can I manually try to PULL UP the downdraft vent after removing the top cover?
