The issue is related to one of the front left burner doesn't heat up properly as we used this burner often and frequently. The other thing to mention here is the hot surface indicator stays on and never turn off if all burner surfaces are even cold or hot. Is this because of bad front left burner and/or bad switch? Please advise, so I can order the correct part for replacement and resolving this issue. Thanks in advance.
