| » down draft not working |
Model Number: cv2236 Brand: Thermador Age: Less than 1 year
My thermador down draft operates up and down but exhaust does not. It was removed due to new counter top.Could the 15 amp. fuse have blown? Or does that not have anything to do with the exhaust
The first thing I would check is proper electrical connections and the two plugs under the stove on the right side.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thank you for your advise. All connections were retwisted and I put on new wire nuts. Still everything works but the exhaust. The two plugs on the right I took off and made sure cleaned. Any more advise would be greatly appreciated.
Gene |
Hi Gene,
Check if 120V is coming to the blower motor while the speed switch is "on". If there is 120V then check the capacitor and the motor windings. If there is no 120V then check the top limit switch and the speed control. Unfortunately I'm not able to find the wiring diagram for your unit and I'm not able to provide more accurate advise. Gene.
__________________
| Display Modes | |
| Thermador down draft | rolandhokan | Oven Repair (including Ranges and Cooktops) | 12 | 03-15-2012 01:55 PM |
| Down draft Ventilation System | estherk | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 12-14-2009 07:27 AM |
| Jenn Air down draft cook top | bEV42 | Oven Repair (including Ranges and Cooktops) | 0 | 08-18-2009 10:42 PM |
| Thermador down draft is misaligned | swenholt | Oven Repair (including Ranges and Cooktops) | 0 | 03-12-2009 03:04 PM |
| CookTop Down Draft Ventilation | DAF | Heating, Ventilation, and Air Conditioning (HVAC) | 0 | 12-08-2007 08:39 AM |
