Discuss
Oven re-ignites occassionally, then quits completely
 in
Hello, I have an intermittent problem with my Whirlpool Gold Accubake oven (Model #: GS440LEMQ). During the normal course of baking
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven re-ignites occassionally, then quits completely
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-18-2008, 12:59 PM
radac radac is offline
Junior Member
radac is on a distinguished road
Default Oven re-ignites occassionally, then quits completely
Model Number: GS440LEMQ   Brand: Whirlpool   Age: 1 - 5 years
Hello, I have an intermittent problem with my Whirlpool Gold Accubake oven (Model #: GS440LEMQ). During the normal course of baking the oven will obviously re-light many times to maintain the set temperature. I have a situation where sometimes the oven will begin to lose heat and never re-light. I can tell when this is about to happen because I'll see the "HEAT" indicator come on, then I'll hear the ignitor start clicking along with the gas coming on. After about 5 clicks, the gas shuts off. After a couple of minutes, it will cycle through and try again. Eventually, it will stop cycling throught the ignition process and just give up completely. At this point, I hit "CANCEL" and wait about 15 mins. to turn on the oven again.
When everything is working, I'll only hear 1 or 2 clicks and then the gas continues to flow (based on the "hissing" sound). It almost seems like the oven realizes that its not getting a good ignition, so it gives up completely.
The rangetop works fine.
Any help would be appreciated...Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-19-2008, 12:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide the most accurate advise I need the complete serial number of the range.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 02-20-2008, 01:46 PM
Junior Member
Default
The serial # is: RP3411691. Thanks.
  #4 (permalink)
Old 02-21-2008, 10:55 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
According to the manufacturer service pointer cause of the intermittent bake burner operation is improper air flow to the burner.
The correction is to replace the bake burner with the new modified burner and igniter assembly.
- The part number for the burner & igniter assembly is AP3598752
__________________
  #5 (permalink)
Old 02-21-2008, 03:01 PM
Junior Member
Default
Hi...Thanks so much for this info. One last question: Is this relatively easy to replace. I'm assuming that you have to at least disconnect power, remove the oven pan and flame spreader. Is it then just a simple remove and replace? Also, do you know if the part comes with some instructions or diagrams? Thanks again.
  #6 (permalink)
Old 02-21-2008, 04:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are on the right track and this part is not too difficult to replace yourself.
I do not think it has any special instructions, but you'll see how it goes after the oven floor and the bottom drawer removed.
__________________
  #7 (permalink)
Old 02-25-2008, 09:21 AM
Junior Member
Default
Hi Gene.
Thanks again for the info. I'd like to go ahead and order this part through this site. I'm wondering though, since my oven is still covered under limited warranty, I should be able to get this part for free from Whirlpool. I asked Whirlpool about this, and they said that was possible only if the part was ordered through a certified Whirlpool technician. Do you know if there is any way to make that happen thru this site? Thanks.
  #8 (permalink)
Old 02-25-2008, 11:18 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by radac View Post
...I'm wondering though, since my oven is still covered under limited warranty, I should be able to get this part for free from Whirlpool. I asked Whirlpool about this, and they said that was possible only if the part was ordered through a certified Whirlpool technician...
To order the part through a certified Whirlpool technician means you have to place a service call with a Whirlpool authorized service company and pay whatever they charge to come over and diagnose.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Built in Oven Completely Dead blacter Oven Repair (including Ranges and Cooktops) 5 01-25-2008 06:15 AM
Maytag washer quits during spin...not unbalanced vbieraugle Washer Repair 1 01-20-2008 03:38 AM
Gas dryer starts fine gas flame runs 10-15 min and then quits Krsolo Dryer Repair 3 10-23-2007 08:44 AM
dryer quits running after a short time magictickler Dryer Repair 1 10-01-2007 02:48 AM
Dishwasher quits at random times pwisor Dishwasher Repair 0 09-04-2007 10:13 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
