The oven will not heat up much past 200. the Broiler seems to work. I checked continuity on the elements and they are fine. Could it be the thermostat, part number 7403P227-60, or is there some other thing I should check first?
You have been a member since:: 11/7/2009(UTC) Posts: 1
Daniel, we are having the exact same problem. where did you find the model# on your unit??? We inherited our stove with our house, and cannot find any indication of model. Would love to know how you solve this issue, as I would rather not buy a new oven prior to a planned kitchen renovation in a couple years!
Kristen
