The red "element on" LED light on one side of my range will not shut off. Both switches on that side are in the off position and the elements are cold, but the light stays on. I'm guessing I have an infinite switch problem here, but I'm not sure how to open up the range to investigate. On page four of this parts list it shows the back panel of my range is a single piece: ftp://ftp.electrolux-na.com/Pr...ssomption/5995377818.pdf Is that what I need to remove? That seems like a big task to get at infinite switches and I don't understand why Frigidaire wouldn't make a seperate top and bottom panel instead.
