I've had our slide in flat top Frigidaire since 2006 and worked perfectly. Then it wouldn't preheat to 350 deg in bake. However the broiler still works. I read some blogs and the concunsus was the culpret was the bake element so I got a new bake element and replaced it. To my dismay the results were the same. I'm hoping it's not the control panel. I would appreciate help in the matter. Thanks in advance.
