I had independent repairman look at oven, he said it needs new upper control board for broiler. I had replaced the igniter before hand seeing that is the usual problem. It did glow before and does still. But the broiler will not heat up. Is there something we missed, the control board is an expensive replacement. thanks for any help. todd
