Oven burner would not light, igniter glowing. Installed new igniter, oven still not lighting. Checked safety valve for continuity, measured 1.4 ohms. Checked voltage at disconnected leads to safety valve, 110v with oven control on, but also found 36v with oven control off?! Looking for suggestions.
