I have a Whirlpool RBD305PDB15 double oven. Recently, after running the self-cleaning cycle, the upper oven will not heat up. The lower over still functions correctly.
The control board is not producing any error codes. Both the upper and lower thermal fuses are good. Both the upper and lower heating elements are good. I verified continuity for all the wiring from control board to the elements.
When I turn on the upper oven, it goes into pre-heat mode and the timer counts down, but the elements never get hot.
If I try to put the upper oven back into self-clean mode, the oven beeps three times and then turns off.
Any ideas?
