Oven shuts of during baking process. Most times, it preheats correctly, then during the bake cycle, when the oven tries to reignite to heat back to set temperature, you can't hear the gas coming out to heat the oven. So what ends up happening is the oven just gets cold and baking gets screwed. I just replaced the gas valve, but I'm still having the same issue.
