Range was installed in 2006. Igniter keeps clicking for front right burner, unless burning. Have cleaned whole assembly several times down to the burner base and dried thoroughly.
At the same time, cleaning cycle seems to be screwed up. Ran all night, but never completed cycle, and did not seem to get as hot as it should have.
Had similar problem with clicking unless back right burner was turned on about a year ago, but that resolved after about 4 weeks. I dealt with it by going downstairs and turning off the fuse except when we needed to run the oven.
Suggestions?
