| » Kitchenaid Range Burner will not work |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: KERC 500 YAL1 Brand: Kitchen Aid Age: More than 10 years
Our Kitchen Aid Stove Glass Stove Top left front burner quit working. I was told it was a surface element. We replaced the surface element and it still is not working. Before replacing the old element the burner would still make the humming sound that it always did while it was heating up. Now that we have replaced it with a new one through AppliancePartsPro it doesn't work and no longer makes the humming sound. Could it be something electrical or a faulty replacement part?
Most likely the cause of the problem is the infinite switch for this burner.
Remove the power from the range. Open the control panel and remove wires from the terminals H1 and H2. Turn the switch "on" and check for continuity across the terminals L1 & H1 and the terminals L2 & H2. If any of these circuits is open - the switch is bad and has to be replaced. - The part number for the infinite switch for the left front burner is AP3008912 Here are the break down diagrams for the Kitchen Aid range Model KERC500YAL1 Gene.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| Right Front Burner Doesn't Work | Babdiver | Oven Repair (including Ranges and Cooktops) | 8 | 05-01-2008 06:50 PM |
| One burner is broken in Glass Top Electric Range | sval79 | Oven Repair (including Ranges and Cooktops) | 0 | 12-31-2007 12:03 PM |
| GE range burner not working | lacucina | Oven Repair (including Ranges and Cooktops) | 0 | 12-29-2007 12:33 PM |
| thermador range extra low burner not lighting | BILL20850 | Oven Repair (including Ranges and Cooktops) | 0 | 10-08-2007 02:44 PM |
| electric range 8 inch burner | handiman | Oven Repair (including Ranges and Cooktops) | 4 | 09-10-2007 09:22 AM |
