My oven burned out the baking element, so I replaced it. So disapointed when I tried to pre heat, and the heat light clicks off after about a min. and the oven cooled down. I then ordered the sensor, and just finished replacing that, and was again disapointed with the same outcome. Any ideas of what I should try next. Thank you
