Bake elements not heating up in both upper or lower oven. Broil elements in both ovens still heating up fine. I pulled bake elements out of both ovens and tested. Have continuity/18.4. Pulled both sensors out reading 1084. Pushed red button on both thermal switches have continuity. From reading other posts from a while back it looks like it could be either control board or relay boards. Is there something I could try to narrow down if I need to buy a control or relay board (s)? Thanks Tony
