The oven temperature is lower than indicated on the control. Broil works fine. For a long while we would simply add 35 degrees to get the desired temp. Now it seems to not go above 150 degrees. I am guessing it is a bad thermostat. If there are other possibilities, would you recommend just calling a repair person to diagnose?
