Hi, my oven is a basic, gas range/oven (Frigidaire FGF337BCD). The oven ignitor glows a bright orange. The oven control panel behaves normally. No error codes.
The intermittent symptoms are: - oven will not light OR - oven lights and burns for a few minutes and then the flames turn off, leaving the ignitor still glowing and the control panel displaying the temp as if everything were normal - sometimes it smells like gas when you turn the oven on and it does not light - sometimes moving the regulator valve closed and then open will cause it to light - ignitor glows a orange color continuously (what color should it be? yellow?) - unplugging oven to reset control panel does not seem to change or help anything
Are these symptoms for ignitor replacement?
Thanks for any and all help!! - Amy
#frigidaire #gas #oven #range #won't stay lit
